[GRASS-user] problem with gis.m on grass 6.2.0
G. Allegri
giohappy at gmail.com
Wed Nov 29 20:50:05 EST 2006
I forgot to do ldconfig this time! It solved the problem. Thank you Hamish.
Giovanni
2006/11/30, Hamish <hamish_nospam at yahoo.com>:
> G. Allegri wrote:
> > I've just compiled 6.2.0 from source. I built it against gdal1.3.2
> > (compiled from source withot). Everythong seems to compile the right
> > way but when I try to open a mapset in grass I receive this error:
> > GRASS 6.2.0 (spearfish60):/usr/local/grass6/bin > Error in startup
> > script: can't read "parts(n)": no such variable
> > while executing
> > "MapCanvas::zoom_new $mon $parts(n) $parts(s) $parts(e) $parts(w)
> > $parts(nsres) $parts(ewres)"
> > (procedure "MapCanvas::zoom_gregion" line 11)
> > I tried "googling" but I haven't found anything to solve it. Can
> > anyone help me?
> Sorry for the opaque error message, we are working that.
> Run "g.region -p" from the command line to see what the real problem is.
> (did you add /usr/local/lib to /etc/ld.so.conf and run ldconfig after
> building & installing GDAL?)
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20061130/9a03102f/attachment.html
