[GRASS-user] AAIGrid import-export problem
Wolfgang
wollez at gmx.net
Thu Nov 30 07:43:53 EST 2006
have you changed g.region to your new settings before export?
Wolfgang
Martin Wegmann schrieb:
> Hello,
> I am stuck with a AAI grid export problem (r.out.gdal input=NAME
> format=AAIGrid type=Byte output=NAME) and I have no clue if it is a gdal
> problem or a GRASS (r.resamp.*) problem.
> 1) Import dataset (r.in.gdal) - export it straight afterwards (r.out.gdal see
> above) - both raster images fit onto each other using QGIS
> 2) Import dataset (r.in.gdal) - applying r.resamp.stats (90m res in 1000m
> res), export with r.out.gdal (see above) - new image has a shift of +/- 100
> Km to the south-east compared to the original image
> I assume its a r.resamp. problem but when I check the header files
> (row,col,res.,proj, etc.) of both exported files, they are the same which
> suprises me because they don't fit on each other.
> Any idea where to investigate further?
> regards, Martin
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
