[GRASS-user] r.what and d.what.rast
    Javier Álvarez Rodríguez
    javier.alvarez at cedex.es
    Wed Oct  4 03:39:02 EDT 2006
Thanks a lot for your answer Trevor. I'm not a good programmer but i tried
to do something more. I exported the map (2300x2900 rowsxcols) to an ascii
file and tried to read there the correct solution. It seems that the correct
one is that given by r.what. Maybe that this is a silly question but,... Do
"d.what.rast" depend on monitor resolution?. I mean the map was 2300x2900
cells and don't know how it manages to select coordinates and then obtain
the value.
Best regards
On Mon, 2 Oct 2006 18:13:16 +0200
Javier Álvarez Rodríguez wrote:
> Hi all,
> My problem is about I'm obtaining different results when using d.what.rast
> and r.what.
> Using interactively d.what.rast on a map named bas, I obtain these
> results:
> 361421.875(E) 4540953.125(N)
> bas in DATOS, quant   (854)
> bas in DATOS, actual  (854.000000)
> Then I write x and y coordinates in a file named pp3.txt
> 361421 4540953 (no matter real or integer coordinates)
> and when using r.what
> r.what bas at DATOS < pp3.txt
> result is 860
I'm not sure of the cause, but in doing some tests of the same data
set, it would appear that r.what is probably reporting incorrectly.
I looked at the code briefly and can't see any obvious errors, but I'm
ccing the developers list to see if anyone has seen this bug before.
T
Trevor Wiens
twiens at interbaun.com
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
grassuser mailing list
grassuser at grass.itc.it
http://grass.itc.it/mailman/listinfo/grassuser
