[GRASS-user] r.what and d.what.rast
Trevor Wiens twiens at interbaun.com
Wed Oct 4 00:56:22 EDT 2006
On Mon, 2 Oct 2006 18:13:16 +0200
Javier Álvarez Rodríguez wrote:
> Hi all,
> My problem is about I'm obtaining different results when using d.what.rast
> and r.what.
> Using interactively d.what.rast on a map named bas, I obtain these
> results:
> 361421.875(E) 4540953.125(N)
> bas in DATOS, quant   (854)
> bas in DATOS, actual  (854.000000)
> Then I write x and y coordinates in a file named pp3.txt
> 361421 4540953 (no matter real or integer coordinates)
> and when using r.what
> r.what bas at DATOS < pp3.txt
> result is 860
I'm not sure of the cause, but in doing some tests of the same data
set, it would appear that r.what is probably reporting incorrectly.
I looked at the code briefly and can't see any obvious errors, but I'm
ccing the developers list to see if anyone has seen this bug before.
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
