[GRASS-user] r.what and d.what.rast
    Glynn Clements
    glynn at gclements.plus.com
    Wed Oct  4 15:40:04 EDT 2006
Javier Álvarez Rodríguez wrote:
> My problem is about I'm obtaining different results when using d.what.rast
> and r.what.
> Using interactively d.what.rast on a map named "bas", I obtain these
> results:
> 361421.875(E) 4540953.125(N)
> bas in DATOS, quant   (854)
> bas in DATOS, actual  (854.000000)
> Then I write "x" and "y" coordinates in a file named "pp3.txt"
> 361421 4540953 (no matter real or integer coordinates)
> and when using r.what
> r.what bas at DATOS < pp3.txt
> result is 860
> Does someone know what is wrong?
Have you tried using the exact coordinates:
361421.875 4540953.125
with r.what?
Also, can you provide the output from "g.region -p"?
