[GRASS-dev] Re: [GRASS-user] r.what and d.what.rast
    Hamish
    hamish_nospam at yahoo.com
    Sun Oct  8 06:08:41 EDT 2006
Trevor Wiens wrote:
> Javier Ãlvarez RodrÃguez wrote:
> > Hi all,
> > My problem is about I'm obtaining different results when using d.what.rast
> > and r.what.
> > Using interactively d.what.rast on a map named bas, I obtain these
> > results:
> > 361421.875(E) 4540953.125(N)
> > bas in DATOS, quant   (854)
> > bas in DATOS, actual  (854.000000)
> > Then I write x and y coordinates in a file named pp3.txt
> > 361421 4540953 (no matter real or integer coordinates)
> > and when using r.what
> > r.what bas at DATOS < pp3.txt
> > result is 860
> I'm not sure of the cause, but in doing some tests of the same data
> set, it would appear that r.what is probably reporting incorrectly.
> I looked at the code briefly and can't see any obvious errors, but I'm
> ccing the developers list to see if anyone has seen this bug before.
The problem is with d.what.rast when zoomed out:
# spearfish dataset
G63> g.region elevation.10m
G63> d.rast elvation.10m
G63> d.what.rast
Buttons
 Left:  what's here
 Right: quit
595509.1750503(E) 4920363.03822938(N)
elevation.10m in PERMANENT, quant   (1432)
elevation.10m in PERMANENT, actual  (1432.339600)
G63> r.what in=elevation.10m east_north=595509.1750503,4920363.03822938
595509.1750503|4920363.03822938||1432.65918
1432.339600  !=  1432.65918
G63> r.stats -1gn elevation.10m | grep 1432.3396
595515 4920365 1432.3396
G63> r.stats -1gn elevation.10m | grep 1432.65918
595505 4920365 1432.65918
Indeed, reported x coordinate is off by one column.
G63> g.region n=4920450 s=n-100  e=595550 w=e-80
G63> d.redraw
G63> d.rast.num elevation.10m
G63> echo -e "width 2\nsymbol basic/circle 30 595509.1 4920363.0 yellow none" \
  | d.graph -m
G63> d.what.rast -c
595509.81707317(E) 4920363.23170732(N), 549(col) 763(row)
elevation.10m in PERMANENT, quant   (1433)
elevation.10m in PERMANENT, actual  (1432.659180)
595510.30487805(E) 4920363.23170732(N), 550(col) 763(row)
So it works ok once zoomed in.
G63> r.what in=elevation.10m east_north=595509.81707317,4920364.20731707
595509.81707317|4920364.20731707||1432.65918
G63> r.what in=elevation.10m east_north=595510.06097561,4920364.08536585
595510.06097561|4920364.08536585||1432.3396
#zooming back out:
g.region rast=elevation.10m
d.redraw
echo -e "width 2\nsymbol basic/circle 5 595509.1 4920363.0 yellow none" \
  | d.graph -m
d.what.rast -c
595518.63321799(E) 4920366.76470588(N), 550(col) 763(row)
elevation.10m in PERMANENT, actual  (1432.462769)
G63> r.stats -1gn elevation.10m | grep 1432.462769
595515 4920375 1432.462769
now d.what.rast's y is off by one row ...
Hamish
ps - display/d.what.rast/what.c
  if (G_get_c_raster_row (fd[i], buf, row) < 0)
should that be G_get_raster_row(,, type) ??
