[GRASS-user] v.transform - output messages
hellik at web.de
hellik at web.de
Sun Oct 15 11:06:26 EDT 2006
hi maciej,
i will try to reproduce it with SPEARFISH 6.0, but it could take time a little bit ...
greetings
helli
-----Ursprüngliche Nachricht-----
Von: Maciej Sieczka <tutey at o2.pl>
Gesendet: 15.10.06 14:09:27
An: Helmut Kudrnovsky <hellik at web.de>
CC: grassuser at grass.itc.it
Betreff: Re: [GRASS-user] v.transform - output messages
Helmut Kudrnovsky wrote:
> i want to move a large polygon-layer by "v.transform " with the following options:
> v.transform
> input=schiechtl_stern_m28
> output=fwoe_mm28_tf45
> xshift=-450000.0
> yshift=0.0
> zshift=0.0
> xscale=1.0
> yscale=1.0
> zscale=1.0
> zrot=0.0
> so a -450000m-shift on the x-axis,
> when i start, i get the following
> output-messages:
> V_ask error: Illegal row (40) in call to V_const
> what do this messages mean?
I don't know but it's not normal I would say. If you could reproduce
that with sperfish60 and submit a bug report with how to reproduce
instruction it could incline some Grass developer to fix it. Could you?
> p.s. is there something similar like v.transform for raster data to move/shift raster data inside grass?
r.region. But it's not that straight-forward as v.transform - you have
to manually calculate the region bounds (N,S,E,W) given the shift you
need, then apply this new region bounds to your raster.
Maciek
______________________________________________________________________
XXL-Speicher, PC-Virenschutz, Spartarife & mehr: Nur im WEB.DE Club!
Jetzt gratis testen! http://freemail.web.de/home/landingpad/?mc=021130
