[GRASS-user] Raster analysis
Wed Oct 18 06:43:54 EDT 2006
Brad Douglas wrote:
> > Please react to the statement below. This is from one shifting from
> > Idrisi to GRASS
> > "I have found that colour manipulation by contrast stretching is not
> > possible in GRASS or am I wrong."
> Sadly, it is correct.  Only 8-bit (integer) color is supported at this
> time.  Adding it to grass/TODO.
Can you elaborate?
Are you referring to the fact that GRASS' colour tables only use 8
bits per component? Or the use of 8 bits per component in the display
architecture? Or something else?
