[GRASS-user] Error building 6.2.0rc2
Luca Casagrande
luca.casagrande at gmail.com
Wed Oct 18 14:15:55 EDT 2006
Hi to all!
I am building 6.0.2rc2, but in the make log, i found some error;
as it says i went to the module folder, and issued make.
This is the output:
localhost g.access # make
gcc
-L/var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib
-Wl,--export-dynamic
-Wl,-rpath-link,/var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib
-DPACKAGE=\""grassmods"\"
-o /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/bin/g.access
OBJ.i386-pc-linux-gnu/exp_perms.o OBJ.i386-pc-linux-gnu/get_perms.o
OBJ.i386-pc-linux-gnu/main.o OBJ.i386-pc-linux-gnu/set_perms.o
-lgrass_gis -lgrass_datetime -lz -lgrass_vask -lbsd-compat -lm
-lz /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
undefined reference to
`endwin' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`nl' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`echo' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`wrefresh' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`waddnstr' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`nonl' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`noecho' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`waddch' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`initscr' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`winch' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`raw' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`wmove' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`wgetch' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`stdscr' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`noraw' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`wclear' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`COLS' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
`curscr' /var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/lib/libgrass_vask.so:
undefined reference to `LINES' collect2: ld returned 1 exit status
make: ***
[/var/tmp/portage/grass-6.2.0_rc2/work/grass-6.2.0RC2/dist.i386-pc-linux-gnu/bin/g.access]
Error 1
What am I missing?
Thanks
Luca
"Chiunque può simpatizzare col dolore di un amico, ma solo chi ha un animo nobile riesce a simpatizzare col successo di un amico (Oscar Wilde)"
LINUX User #411601
GENTOO-GIS Development Team
jabber: casagrande at jabber.linux.it
