[GRASS-user] r.watershed hangs
Hamish
hamish_nospam at yahoo.com
Sun Oct 22 21:03:26 EDT 2006
Hardeep Singh Rai wrote:
> I was doing watershed analysis for spearfish dataset
> (spearfish_grass60data-0.1.tar.gz), and on giving command:
> r.watershed elevation=elevation.dem threshhold=3 basin=raiBasin
> accumulation=raiAccu it starts processing of 5 steps. After about 20
> minutes, it completes all and throw message: "cloing maps", but do
> nothing; prompt never comes. I used it with option -m and without it.
> With both cases, "top" commands show ram or sed running with 99 usage
> of CPU. Even I waited for 12 hours, but it fail to finish. I am using
> GRASS 6.0.1 on Ubuntu.
> Please suggest some solution.
It's a known bug (#3112). It gets stuck trying to make a huge set of
colormap rules for the new map. If you cancel (^C) you might find the
map was created anyway (???).
Try running with a smaller region (g.region)
I don't think it's a hard bug to fix, but no one has done it.
r.watershed bug reports:
https://intevation.de/rt/webrt?q_status=open&q_queue=grass&q_subject=r.watershed
another work-around: try the r.terraflow module. It is much more
advanced and can make watershed maps.
Hamish
