[GRASS-user] v.surf.rst geological surfaces
Francesco Mirabella
mirabell at unipg.it
Thu Oct 26 06:18:07 EDT 2006
Hi Maciej and list,
thanks for your reply, I will try to get some more info about tangential
curvatures.
By the way, does anyone know if GEOLOGICAL SURFACES like fault planes or
bedding planes (not "phenomena", like gas emissions, etc.) can be modeled with
v.surf.rst? or with some other grass-command? Has anyone done it?
cheers
Francesco
On Wed, Oct 25, 2006 at 05:05:19PM +0200, Maciej Sieczka wrote:
> Francesco Mirabella wrote:
> > Dear all,
> > I'm working on a 3D vector map of a geological surface. I tried to
> > interpolate the points with v.surf.rst getting an elevation raster map
> > which is attached to this email as image. The surface changes its depth along a
> > curved line (see the attachment). Is there a way to tune the v.surf.rst
> > command in order to make it take into account of the curvature?
> > Is "tcurv" option doing it?
> tcurv=string
> Output tangential curvature raster file
