[GRASS-user] v.surf.rst geological surfaces
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Oct 26 13:31:18 EDT 2006
Hi Francesco,
it is possible "model" discontinuous features (the gully example in the GRASS
book [1] comes to mind) however there are important limitations that you must
consider. Try searching past archives of this list- for some rather long
discussions on a similar topic: breaklines, rst, nnbathy.
Maciej has implemented an alternate interpolator which may do what you need.
Post back with your results, or further questions if the archives do not help.
Cheers,
Dylan
On Thursday 26 October 2006 03:18, Francesco Mirabella wrote:
> Hi Maciej and list,
> thanks for your reply, I will try to get some more info about tangential
> curvatures.
> By the way, does anyone know if GEOLOGICAL SURFACES like fault planes or
> bedding planes (not "phenomena", like gas emissions, etc.) can be modeled
> with v.surf.rst? or with some other grass-command? Has anyone done it?
> cheers
> Francesco
> > > Dear all,
> > > I'm working on a 3D vector map of a geological surface. I tried to
> > > interpolate the points with v.surf.rst getting an elevation raster map
> > > which is attached to this email as image. The surface changes its depth
> > > along a curved line (see the attachment). Is there a way to tune the
> > > v.surf.rst command in order to make it take into account of the
> > > curvature? Is "tcurv" option doing it?
> > tcurv=string
> > Output tangential curvature raster file
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
