[GRASS-user] Error with g.mapsets in 6.1
Glynn Clements
glynn at gclements.plus.com
Fri Sep 1 11:34:03 EDT 2006
Luca Casagrande wrote:
> Hi to all!
> I am building a livecd for the Foss4g2006 and grass 6.1 is intside it.
> If i try to open a raster or a vector from the dm, I got this error:
> couldn't execute "g.mapsets": no such file or directory
> while executing
> "exec g.mapsets -p"
> (procedure "GSelect_::create" line 33)
> invoked from within
> "GSelect_::create $element"
> (procedure "GSelect" line 3)
> invoked from within
> "GSelect cell"
> Opening the layer via shell is working fine...
> This command it's not available in 6.1 neither from shell ( i got 6.0.2 on
> the same livecd and g.mapsets is working fine)
If you compiled from source, you need to determine why g.mapsets
failed to compile.
If you are using a binary package, you need to notify the creator of
the binary package, identifying exactly which package you are
referring to.
