[GRASS-user] [GRASSLIST:1186] Re: wrong mailing list [was: problems
in sourcing R script]
Ulrich Leopold
uleopold at science.uva.nl
Mon Sep 18 05:37:31 EDT 2006
Sorry this question went to the wrong mailing list. My appologies.
Best regards, Ulrich
On Mon, September 18, 2006 11:32, Ulrich Leopold wrote:
> Dear list,
> First my information:
> platform i386-pc-linux-gnu
> arch i386
> os linux-gnu
> system i386, linux-gnu
> status
> major 2
> minor 3.1
> year 2006
> month 06
> day 01
> svn rev 38247
> language R
> version.string Version 2.3.1 (2006-06-01)
> Now my question:
> How is it possible that a command in an R script is not executed completely
> whereas the same command is fully executed when I copy paste it to the R
> terminal?
> It is the last command "summary(....)" which shows such behaviour.
> The result of the execution is:
> Df Sum of Sq RSS AIC
> <none> 18.666 -49.277
> - Flower 1 2.113 20.779 -45.700
> It does not compute the summary statistics any more.
> Whereas this is the result when I copy paste the comamnd into the R terminal:
> Call:
> lm(formula = NH4Mar04 ~ Flower, data = N)
> Residuals:
> Min 1Q Median 3Q Max
> -1.0750 -0.1968 -0.1518 -0.0968 2.9632
> Any ideas what the problem could be?
> Is it possible that there is some kind of character problem or a hidden
> control character in the text file or an encoding problem (I use UTF)? I
> checked already with cat -A whether it shows unwanted control characters but
> nothing showed up.
> I also used 2 different text editors to see whetehr it is related to a text
> editor.
> Thanks, Ulrich
> R.script sourced with
>> source("script.R")
> # Load MASS library for stepAIC, truehist, etc.
> library(MASS)
> # Read in the data as comma separated file
> N <- read.csv2("MatrixNO3_08Aug06.csv", header=TRUE, sep=";", dec=".")
> # Compute stepwise generalised linear regression
> summary(stepAIC(lm(NH4Mar04~Elevation+Soil1+Soil2+Text1+Text2+Text3+Rice+Cabbage+Squash+Chilli+Flower,
> N)))
> And here is the example for reproduction:
> N <-
> structure(list(samplePCR... = as.integer(c(1, 2, 3, 4, 5, 6,
> 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22,
> 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38,
> 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52)), Elevation = c(12.9,
> 12.9, 12.9, 12.9, 12.9, 12.9, 13.1, 13.1, 13.2, 13.3, 13.1, 13,
> 13.2, 13.3, 13.4, 13.6, 13.5, 13.5, 13.3, 13, 12.8, 13.8, 14.1,
> 13.2, 13.1, 12.5, 12, 11.8, 12.4, 13.8, 13.7, 12.8, 12.9, 12.8,
> 12.8, 12.7, 12.5, 12.4, 12.4, 12.5, 12.2, 12.3, 11.8, 13.7, 13.8,
> 13.8, 13.9, 13, 12.9, 13.9, 13.6, 13.8), Soil1 = as.integer(c(1,
> 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0,
> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0, 0, 1, 0, 0, 0, 0, 0, 0)), Soil2 = as.integer(c(0, 0, 0, 0,
> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1,
> 1, 1, 1, 1, 1, 1)), Text1 = as.integer(c(1, 1, 1, 1, 1, 1, 1,
> 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 0,
> 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1,
> 1, 0, 0)), Text2 = as.integer(c(0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 1, 1, 1, 1,
> 1, 1, 1, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 1, 1
> )), Text3 = as.integer(c(0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0)), Rice =
> as.integer(c(0 ,
> 0, 0, 1, 1, 1, 0, 0, 0, 1, 1, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1,
> 1, 1, 0, 1, 0, 0, 0, 0, 0)), Cabbage = as.integer(c(0, 0, 0,
> 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 1, 1, 1, 0, 0, 1,
> 1, 0, 0, 0, 0, 0, 0)), Squash = as.integer(c(1, 1, 1, 1, 1, 1,
> 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0, 0, 0, 0)), Chilli = as.integer(c(0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0, 0, 0, 0, 0, 0, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1,
> 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0)), Flower = as.integer(c(0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0)), NO3Mar04 = c(16.04,
> 7.24, 19.65, 19.87, 20.64, 18.72, 17.24, 8.84, 26.2, 6.04, 4.35,
> 20.6, 14.44, 10.24, 19.48, 19.52, 10.8, 10.8, 2.92, 38.8, 5.38,
> 41.04, 37.18, 20.6, 18.12, 6.04, 22.85, 29.56, 28.35, 28.24,
> 20.35, 20.65, 22.85, 7.49, 10.8, 6.92, 31.8, 28.7, 24.2, 26.76,
> 18.16, 20.3, 35.16, 33.73, 21.73, 22.42, 27.88, 6.84, 10.52,
> 10.24, 20.04, 16.92), NO3Aug04 = c(13.84, 11.36, 4.64, 13.64,
> 12.64, 11.42, 19.87, 2.04, 11.76, 1.28, 13.06, 11.87, 2.68, 9.12,
> 2.68, 4.92, 14.85, 4.08, 10.75, 12.48, 16.68, 27.16, 22.28, 2.96,
> 12.88, 22.84, 15.35, 8.04, 8.66, 1.28, 23.84, 25.77, 28.6, 1.28,
> 23.18, 8.84, 20, 21.84, 9.98, 37.9, 17.8, 21.27, 10.32, 1.98,
> 0.83, 1.18, 2.68, 11.08, 14.44, 7.84, 13.88, 5.48), NH4Mar04 = c(0.76,
> 0.68, 0.79, 0.79, 0.79, 0.78, 0.77, 3.92, 1.12, 1.12, 0.66, 0.84,
> 0.84, 0.56, 1.12, 0.78, 0.56, 1.12, 0.65, 0.84, 0.67, 3.08, 0.93,
> 0.56, 0.77, 0.84, 0.81, 1.4, 0.86, 0.86, 0.79, 0.79, 0.81, 0.68,
> 0.84, 0.68, 1.4, 0.86, 0.82, 1.68, 0.77, 0.79, 0.84, 0.9, 0.8,
> 0.81, 0.84, 0.68, 0.56, 1.4, 3.08, 0.76), NH4Aug04 = c(0.78,
> 0.69, 2.24, 0.77, 1.12, 0.7, 0.98, 0.84, 0.71, 0.84, 0.75, 0.71,
> 1.12, 1.68, 0.84, 0.56, 0.81, 0.84, 0.67, 1.96, 0.87, 1.12, 1.4,
> 0.84, 0.75, 1.12, 0.83, 1.12, 0.6, 0.56, 1.11, 1.18, 1.96, 0.84,
> 1.09, 2.24, 1.4, 1.05, 0.65, 1.68, 0.84, 1.03, 1.12, 0.38, 0.34,
> 0.35, 1.4, 0.5, 1.68, 1.4, 1.96, 3.08), NO3Mar05 = c(5.5, 19.6,
> 6, 6.2, 5.6, 5.2, 5.1, 10.4, 12.2, 13.44, 9.7, 8.12, 5.88, 8.9,
> 7.8, 13.44, 12.6, 14.56, 14.4, 10.64, 11.5, 29.04, 22.08, 2.8,
> 5.5, 7, 6.1, 5.88, 12.6, 9.53, 4.9, 8.4, 5.9, 6.44, 12.32, 22.96,
> 7.28, 5.88, 6.12, 6.16, 1.96, 6.72, 6.46, 5.64, 5.38, 12.24,
> 5.04, 7.56, 2.96, 8.4, 1.68, 1.76), NO3Aug05 = c(6.74, 3.36,
> 2.8, 6.4, 8.2, 4.2, 8.2, 9.1, 9.46, 8.64, 8.57, 3.64, 5.87, 6.98,
> 7.48, 11.64, 4.48, 3.36, 7.86, 8.96, 7.68, 10.16, 12.8, 8.24,
> 5.25, 5.44, 6.24, 9.72, 8.67, 8.54, 12.4, 11.56, 11.04, 10.48,
> 9.64, 9.89, 8.08, 7.68, 6.84, 7.02, 6.89, 8.04, 5.76, 5.86, 6.26,
> 8.96, 13.07, 7.28, 11.28, 6.72, 7.46, 6.52), NH4Mar05 = c(0.84,
> 0.28, 0.84, 0.68, 0.84, 0.92, 0.96, 0.56, 0.62, 0.56, 0.48, 0.56,
> 0.84, 0.48, 0.62, 0.84, 0.95, 2.24, 0.58, 0.56, 0.52, 2.24, 0.28,
> 0.28, 0.72, 0.84, 0.72, 0.84, 0.96, 0.56, 0.68, 1.12, 0.7, 0.7,
> 0.56, 0.56, 0.56, 0.52, 0.54, 0.28, 0.84, 0.56, 0.56, 0.49, 0.5,
> 0.52, 0.56, 1.68, 0.22, 0.28, 0.28, 0.26), NH4Aug05 = c(0.64,
> 1.96, 0.56, 0.68, 0.64, 1.12, 0.76, 0.56, 0.6, 0.56, 0.62, 0.56,
> 0.64, 0.52, 0.62, 0.64, 0.56, 0.84, 0.78, 1.12, 0.68, 1.12, 1.24,
> 0.48, 0.58, 0.64, 0.63, 0.64, 0.76, 0.78, 1.68, 0.86, 0.74, 0.68,
> 0.56, 0.64, 0.62, 0.54, 0.52, 0.32, 0.64, 0.56, 0.58, 0.58, 0.48,
> 0.54, 0.72, 2.24, 0.84, 0.56, 0.38, 0.36)), .Names = c("samplePCR...",
> "Elevation", "Soil1", "Soil2", "Text1", "Text2", "Text3", "Rice",
> "Cabbage", "Squash", "Chilli", "Flower", "NO3Mar04", "NO3Aug04",
> "NH4Mar04", "NH4Aug04", "NO3Mar05", "NO3Aug05", "NH4Mar05", "NH4Aug05"
> ), class = "data.frame", row.names = c("1", "2", "3", "4", "5",
> "6", "7", "8", "9", "10", "11", "12", "13", "14", "15", "16",
> "17", "18", "19", "20", "21", "22", "23", "24", "25", "26", "27",
> "28", "29", "30", "31", "32", "33", "34", "35", "36", "37", "38",
> "39", "40", "41", "42", "43", "44", "45", "46", "47", "48", "49",
> "50", "51", "52"))
Ulrich Leopold MSc.
Dep. Phys. Geography and Soil Science
Inst. for Biodiversity and Ecosystem Dynamics
Faculty of Science
University of Amsterdam
Nieuwe Achtergracht 166
NL-1018 WV Amsterdam
Phone: +31-(0)20-525-7456 (7451 Sectretary)
Fax: +31-(0)20-525-7431
Email: uleopold at science.uva.nl
http://www.science.uva.nl/ibed/cbpg/index.html
