[GRASS-user] ArcGIS, GRASS and employability
Jachym Cepicky jachym.cepicky at centrum.cz
Tue Sep 19 13:55:38 EDT 2006
as you said, grass "foreces" more than other programs, to see how does
it work inside. when I started, I had just one semester experience with
arc view 4. I completly learnt "how to gis" with grass. later on, I was
able to work with idrisi or arc gis without need of much time to learn
them.
for more "advanced" users and programers, in grass you can learn, how the
geospatial operations can be done - it is open source.
jachym
On Tue, Sep 19, 2006 at 12:20:05PM -0500, Martin du Saire wrote:
> Hey,
> Being a complete novice in GIS, and having only
> used ESRI products a handful of times, How does
> ArcGIS/ESRI hinder student understanding?  Isn't
> it the responsibility of the student/instructor
> to look inside the black-box?  Maybe GRASS
> "forces" one to look inside, but I'm sure there
> have been times when I have cut and paste a GRASS
> command without fully understanding what's going
> on behind the scenes (did I mention I am a novice).
> Just wondering.
> M
> At 01:14 AM 9/19/2006, you wrote:
> >Hallo,
> >imho university should be here in general to teach principals. Not to
> >prepare the students for the praxis.
> >GRASS is perfect didactical tool, it makes you understand, how it works
> >and what steps must be done befor you get your result.
> >GRASS has also that advantage, that it can be used be the students on
> >their computers (pc/mac), so they can work at home.
> >Just my two cents
> >Jachym
> >On Mon, Sep 18, 2006 at 04:58:49PM +0000, Roy Sanderson wrote:
> >> Hello Tom, Michael and others
> >> Thanks for your comments on this.  I was somewhat baffled by the external
> >> examiner's report, as student feedback had been very positive on the
> >> course.  Perhaps he thought GRASS was only used in education?  I did
> >> demonstrate a few ArGIS features to the students at the end of the
> >course,
> >> but it was noticable that only one of them wanted to use it when it came
> >to
> >> their projects, and the rest stuck to GRASS.
> >> Best wishes
> >> Roy
> >> At 10:43 18/09/06 -0400, Thomas Adams wrote:
> >> >Michael,
> >> >Completely agree. One might also go to
> >> >http://grass.itc.it/community/index.php to see the international use of
> >> >GRASS GIS and to http://gmt.soest.hawaii.edu/ for the use of GMT, which
> >> >many GRASS GIS users also use extensively. The assertion that GRASS is
> >> >not used outside of Newcastle is an openly inflammatory and contentious
> >> >remark and clearly not grounded in fact.
> >> >So, one would also presume that UNIX, Linux, and MacOS X should not be
> >> >used in an academic setting for the same reason, that is, that
> >> >MS-Windows dominates, soÂ
> >> >Tom
> >> >Michael Barton wrote:
> >> >> Roy,
> >> >> You'll probably get a lot of response on
> >this, but I'll add a bit here. In
> >> >> terms of not being known outside Newcastle, take a look at the
> >> >> user/developer map on the GRASS web site.
> >I'm in Arizona, USA--quite a ways
> >> >> from Newcastle--and we are using GRASS in
> >research projects and teaching it
> >> >> to students here.
> >> >> Because many companies use ESRI products, it will be useful for
> >students
> >> >> seeking employment in those companies to have some familiarity with
> >ESRI
> >> >> software. However, they will go farther if they have a good
> >> understanding of
> >> >> GIS concepts, and especially how to use
> >GIS to solve problems, than simply
> >> >> the techniques of how to push which
> >buttons. People who actually know what
> >> >> to use GIS for, can get up to speed in
> >different systems pretty fast. So an
> >> >> overview of different software, including
> >ESRI, might be a good addition to
> >> >> a course that uses GRASS to more effectively teach how to use GIS.
> >> >> Also, those who are employed in places
> >where the results are more important
> >> >> than the software used might do better
> >with GRASS--e.g. those focusing on
> >> >> research or in consulting.
> >> >> Michael
> >> >> __________________________________________
> >> >> Michael Barton, Professor of Anthropology
> >> >> School of Human Evolution & Social Change
> >> >> Center for Social Dynamics & Complexity
> >> >> Arizona State University
> >> >> phone: 480-965-6213
> >> >> fax: 480-965-7671
> >> >> www: http://www.public.asu.edu/~cmbarton
> >> >>> From: Roy Sanderson <R.A.Sanderson at newcastle.ac.uk>
> >> >>> Date: Mon, 18 Sep 2006 08:51:47 +0000
> >> >>> To: <grassuser at grass.itc.it>
> >> >>> Subject: [GRASS-user] ArcGIS, GRASS and employability
> >> >>> Hello
> >> >>> Last spring I converted a short course I
> >give to some of our MSc students,
> >> >>> from ArcGIS 9 to GRASS 6.0.  Whilst the
> >students had had no prior exposure
> >> >>> to GIS (or indeed Linux), it was obvious that they progressed through
> >> their
> >> >>> work much more rapidly and learnt more in terms of the fundamental
> >> >>> concepts, and I was pleased with the overall results.
> >> >>> However, the External Examiner's report for the MSc has criticised
> >the
> >> >>> change to GRASS, stating that "it isn't
> >known outside Newcastle" and that
> >> >>> it is harming the students' employment prospects on graduation.  The
> >> >>> examiner is clearly wanting me to go back to using something like
> >> ArcGIS or
> >> >>> MapInfo in the GIS module.
> >> >>> It would be useful if anyone could
> >provide me with a few facts/figures on
> >> >>> the use of GRASS outside of academia,
> >especially in any large commercial
> >> >>> companies etc.
> >> >>> Many thanks
> >> >>> Roy
> >> >>> Roy Sanderson
> >> >>> Institute for Research on Environment and Sustainability
> >> >>> Devonshire Building
> >> >>> University of Newcastle
> >> >>> Newcastle upon Tyne
> >> >>> NE1 7RU
> >> >>> United Kingdom
> >> >>> Tel: +44 191 246 4835
> >> >>> Fax: +44 191 246 4999
> >> >>> http://www.ncl.ac.uk/environment/
> >> >>> r.a.sanderson at newcastle.ac.uk
> >> >> _______________________________________________
> >> >> grassuser mailing list
> >> >> http://grass.itc.it/mailman/listinfo/grassuser
> >> >Thomas E Adams
> >> >National Weather Service
> >> >Ohio River Forecast Center
> >> >1901 South State Route 134
> >> >Wilmington, OH 45177
> >> >EMAIL:       thomas.adams at noaa.gov
> >> >VOICE:       937-383-0528
> >> >FAX: 937-383-0033
> >Jachym Cepicky
> >e-mail: jachym.cepicky at centrum.cz
> >URL: http://les-ejk.cz
> >GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
> >OFFICE:
> >GDF-Hannover
> >Mengendamm 16d
> >30177 Hannover
> >Germany
> >e-mail: cepicky at gdf-hannover.de
> >URL:    http://gdf-hannover.de
> >Tel.:   +49 511-39088507
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060919/6344449b/attachment.bin
