[GRASS-user] intersect vector line by vector point
Maciej Sieczka
tutey at o2.pl
Thu Sep 21 10:49:02 EDT 2006
Michaël Rabotin wrote:
> Hi everybody, i'm a rooky on GRASS 6.01 (ubuntu) and i search a command to
> intersect a vector line by a vector point (so the points on the lines cut
> the lines in the output file).
> Does anyone have a solution to threat this problem ?
Are your "points" and "lines" separate files?
If so, and the points are located exactly along the lines, try to
v.patch the 2 files, then v.clean tool=break.
Maciek
