[GRASS-user] error on startup
Jeroen Wortel
j.wortel at orange.nl
Sat Sep 23 18:29:11 EDT 2006
Hi all,
I found the problem, I had an outdated version of gdal, after
building a fresh one the build of Grass 6.2.0beta3 worked fine.
sorry to have bothered you,
-Jeroen.
At 15:49 23-9-2006, Jeroen Wortel wrote:
>Hi,
>After compiling grass 6.2.0beta3 with no apparent errors in make I
>get the following error at startup, and d.m or gis.m won't start:
>See the licence terms with: g.version -c
>If required, restart the graphical user interface with: gis.m &
>When ready to quit enter: exit
>GRASS 6.2.0beta3 (NZ):~/grass-6.2.0beta3 > Error in startup script:
>can't read "monitor_zooms(1,1,n)": no such variable
> while executing
>"lappend region $monitor_zooms($mon,1,$attr)"
> (procedure "MapCanvas::currentzoom" line 13)
> invoked from within
>"MapCanvas::currentzoom $mon"
> (procedure "MapCanvas::coordconv" line 23)
> invoked from within
>"MapCanvas::coordconv $mon"
> (procedure "MapCanvas::create" line 68)
> invoked from within
>"MapCanvas::create"
> (procedure "Gm::startmon" line 11)
> invoked from within
>"Gm::startmon"
> (procedure "Gm::create" line 69)
> invoked from within
>"Gm::create"
> (procedure "main" line 30)
> invoked from within
>"main $argc $argv"
> (file "/usr/local/grass-6.2.0beta3/etc/gm/gm.tcl" line 522)
>Can you help outhere?
>thanks,
>-Jeroen.
>_______________________________________________
>grassuser mailing list
>grassuser at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grassuser
RC(0.3)1r2m B-- C-- D++ F N- S? O! OCGP a29
