[STATSGRASS] RE: [GRASS-user] kriging
    Maciej Sieczka
    tutey at o2.pl
    Mon Sep 25 08:35:32 EDT 2006
Markus Neteler wrote:
> Maciej Sieczka wrote on 09/25/2006 12:12 PM:
>> ehizcara at agrogex.com wrote:
>>>> Eduardo, thanks a lot. Before I decide what will I use - what about applying
>>>> fault lines? Is it possible to incorporate those as lines where stops
>>>> interpolations?
>> The only FOSS I know that supports fault lines (if that's what you
>> mean) is Surfit http://surfit.sourceforge.net
>> Examples: http://surfit.sourceforge.net/surfit/examples.html.
>> Maciek
> Luckily GRASS can do that, too:
> http://mpa.itc.it/markus/grass61/demos/gully_surf_rst.jpg
> .. taken from our GRASS book,
>  section 7.3.5 Surfaces with faults.
Markus,
That's not the same. I don't you can achieve this:
http://surfit.sourceforge.net/surfit/fault_8tcl-example.html
http://surfit.sourceforge.net/surfit/fault__approx_8tcl-example.html
using Grass. In Grass you can't use lines as interpolation faults. The
method you refer to uses area masking, and it can't reproduce the
Surfit examples.
Maciek
