[STATSGRASS] RE: [GRASS-user] kriging
Māris Nartišs
maris.gis at gmail.com
Mon Sep 25 13:03:19 EDT 2006
Hi Maciek,
I will disagree with You - as
http://surfit.sourceforge.net/surfit/fault__approx_8tcl-example.html says:
"The main idea of fault curves is that parts of resulting surface between
fault curve are independent of each other."
It's like masking areas between fault lines, interpolating them seperatly and
patching together. Only difference - in GRASS you must do it manualy for each
fault-enclosed area.
Maris.
On Monday 25 September 2006 15:35, Maciej Sieczka wrote:
> Markus,
> That's not the same. I don't you can achieve this:
> http://surfit.sourceforge.net/surfit/fault_8tcl-example.html
> using Grass. In Grass you can't use lines as interpolation faults. The
> method you refer to uses area masking, and it can't reproduce the
> Surfit examples.
> Maciek
