[GRASS-user] RE: Problem querying layers other than '1' in gi s.m
Dylan Beaudette dylan.beaudette at gmail.com
Mon Sep 25 12:57:27 EDT 2006
Eric,
One way to avoid this problem in the future is with a SQL like:
CREATE TABLE new_table AS
SELECT table_a.really_long_column_name as id, table_b.some_column as temp
from table_a join table_b
on table_a.key = table_b.key ;
i.e. rename the columns inline with the query.
cheers,
Dylan
On Monday 25 September 2006 09:13, Patton, Eric wrote:
> I tried renaming within sqlitebrowser to no avail. I posted the error
> within my message a few posts ago. I'm unfamiliar with a lot of the SQL
> syntax, but I tried:
> ALTER TABLE  Video_Benthos
> RENAME Rumbolt_Video_Benthos_Uncorrected_UTC_NR.ID ID ;
> But I'm most likely getting the syntax incorrect. Any ideas?
> ~ Eric.
> -----Original Message-----
> From: Moritz Lennert
> To: Patton, Eric
> Cc: ''Dylan Beaudette ' '; ''grassuser at grass.itc.it' '
> Sent: 9/25/2006 11:23 AM
> Subject: Re: [GRASS-user] RE: Problem querying layers other than '1' in gi
> s.m
> Patton, Eric wrote:
> >>> Could the error I'm getting be caused by the length of the new field
> >>> names?
> >> I think the problem is rather the period in the name.
> >>From the Postgresql documentation:
> >> "SQL identifiers and key words must begin with a letter (a-z, but
> also
> >> letters with diacritical marks and non-Latin letters) or an
> underscore
> >> (_). Subsequent characters in an identifier or key word can be
> letters,
> >> underscores, digits (0-9), or dollar signs ($)."
> >> Moritz
> > Strange then that Sqlite writes these column names itself?!
> No time to check this now, but probably sqlite allows such column names,
> but GRASS tries to enforce SQL standards which probably don't allow
> them.
> > I exported the
> > tables as csv, opened it in OOffice, and just renamed the columns. It
> seems
> > to be behaving now.
> Couldn't you modify them in sqlite directly ?
> Moritz
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
