[GRASS-user] problem inporting large datasets with
v.in.ascii
Jeroen Wortel
j.wortel at orange.nl
Tue Sep 26 14:22:36 EDT 2006
Hi Mike,
You are right, importing with th -b switch cuts down considerably on
memory usage.
eventually I used r.in.xyz which was very suitable for this dense
dataset. setting the memory switch to 50% imported 18 mln points into
a raster without any problem.
thanks,
-Jeroen.
At 09:47 23-9-2006, Michael Perdue wrote:
>Jeroen,
>if you're working with with point data then you can use the -b switch
>so that grass doesn't build topology. However, as far as I'm aware,
>v.surf.rst is the only other module that will work without topology
>so you might want to consider breaking your data up into smaller chunks.
>Cheers,
>Mike
>On 22-Sep-06, at 12:52 PM, Jeroen Wortel wrote:
>>Hi all,
>>I tried to import a large xyz ( 7 mln points) dataset with
>>v.in.ascii, but got the following message:
>>registering lines: G_realloc: out of memory
>>At the start of v.in.ascii I had 1.5GB memory free, but during
>>v.in.ascii leaked slowly away ( when checking with top) to 0.
>>Any ideas?
>>I use grass-6.2 cvs, this weeks update
>>thanks,
>>-Jeroen.
>>_______________________________________________
>>grassuser mailing list
>>grassuser at grass.itc.it
>>http://grass.itc.it/mailman/listinfo/grassuser
>__________________________________________________
>Do You Yahoo!?
>Tired of spam? Yahoo! Mail has the best spam protection around
>http://mail.yahoo.com
RC(0.3)1r2m B-- C-- D++ F N- S? O! OCGP a29
