[GRASS-user] Changing colour tables
    Jarek Jasiewicz
    jarekj at amu.edu.pl
    Tue Apr  3 12:13:23 EDT 2007
pawan datta napisał(a):
> Dear All,
> I am having problems with changing color rules for a raster map. I
> have three different DEM's obtained from different sources and i have
> set the color for each as predefined color rule 'contour'. My problem
> is that I want to have all the 3 DEM's use the same color scheme i.e.,
> each height range (700-800m, 800-900m and so on) in all the rasters is
> represented by the same color. Could somebody please help me with
> this. Also, I want to change the color table so that it uses absolute
> values instead of relative values.
> Thank You very much in advance..
> Pawan Datta
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
simply prepare rule file for map with hihger difference between lower
and upper values with:
0 0 128 0
100 0 200 0
etc
than use:
r.colors map=map_to rast=map_from
Jarek
