[GRASS-user] Odd vector point placement
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Apr 5 01:50:45 EDT 2007
Hi Richard,
most GIS systems want the coordinates to be in x,y or
longitude-latitude order. I do not think that your (-21, 149)
coordinate pair is in the correct order -- could this be a source of
the problems?
cheers,
Dylan
On 4/4/07, Richard Chirgwin <rchirgwin at ozemail.com.au> wrote:
> All,
> I have a set of vector points captured as decimal latitude / longitude,
> in a Mysql database.
> I am looking at a point which in the Map display is showing in the wrong
> place. In the database field, the point is captured as being at -21.133,
> 149.1833.
> The point displays at the correct latitude, but at longitude 153.81 (at
> least if I look at the map display with the mouse pointer!).
> If I query the point, it shows the right lat/long, and the hundreds of
> other points in the database seem to be coming up with the right spots.
> Any thoughts?
> Richard Chirgwin
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
