[GRASS-user] building cvs hangs
    Glynn Clements
    glynn at gclements.plus.com
    Sat Apr 14 19:08:17 EDT 2007
Seb wrote:
> I'm experiencing problems building GRASS cvs today.  The build process is
> hanging at this step:
> ---<---------------cut here---------------start-------------->---
> GISRC=/usr/local/src/grass-cvs/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc63 GISBASE=/usr/local/src/grass-cvs/dist.x86_64-unknown-linux-gnu PATH="/usr/local/src/grass-cvs/dist.x86_64-unknown-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/usr/local/src/grass-cvs/dist.x86_64-unknown-linux-gnu/bin:/usr/local/src/grass-cvs/dist.x86_64-unknown-linux-gnu/lib:" LC_ALL=C /usr/local/src/grass-cvs/dist.x86_64-unknown-linux-gnu/bin/r.colors --html-description | grep -v '</body>\|</html>' > r.colors.tmp.html ; true
> ---<---------------cut here---------------end---------------->---
This was due to my recent change to G_parser(); --html-description was
getting stuck in an infinite loop.
If you kill the offending r.colors process, the build will continue.
This has already been fixed in CVS.
