[GRASS-user] raster to vector conversion
Glynn Clements
glynn at gclements.plus.com
Sun Apr 15 08:38:52 EDT 2007
Tom Miewald wrote:
> I am wondering if there is a way to convert raster to vector in GRASS
> without the smoothing. I want to keep the "blocky" look of the raster
> boundaries to their original pixel extents. I find too much detail is lost
> with the smoothing. Are there any other open source methods to do this if
> from the GRASS help: "To produce a better-looking vector map,
> *r.to.vect*smoothes the corners of the vector data as they are being
> extracted.
It only does this if you use the -s flag; otherwise, you get hard
corners.
