[GRASS-user] MODIS US NDVI import/reproject problem
Markus Neteler
neteler at itc.it
Wed Apr 18 12:19:41 EDT 2007
On Wed, Apr 18, 2007 at 08:54:29AM -0700, Steve Swanson wrote:
> I'm trying to subset the MODIS US NDVI composites and get it into UTM
> in another mapset-- the metadata is not well documented, as has been
> noted, but are apparently in Albers Equal Area Conic projection. I
> read through the archives and followed Marcus' suggestions for
> changing projection info (spheroid and datum) and used r.in.gdal, but
> the data come in UTM about 19.3km north of where they should be, may
> be slightly off east-west, but can't tell for sure. Has anybody
> found a solution to working with these ddata in GRASS?
Where did you get these data?
My script only applied to original HDF files from NASA EOS Data Gateway.
Markus
