[GRASS-user] v.digit cannot update table
Seb
spluque at gmail.com
Sat Apr 21 16:11:39 EDT 2007
On Sat, 21 Apr 2007 20:50:19 +0100,
Glynn Clements <glynn at gclements.plus.com> wrote:
> Can you try it with:
> export DEBUG=3
Yes, I tried it with that, but I don't see more messages. Here's the
output after trying to draw a square:
---<---------------cut here---------------start-------------->---
v.digit -n map=newvect bg="d.vect coastline"
New empty map created.
PNG: GRASS_TRUECOLOR status: TRUE
PNG: collecting to file:
/home/sluque/GRASSDATA/Coast_geo/sluque/.tmp/patagonia/18803.0.ppm,
GRASS_WIDTH=642, GRASS_HEIGHT=289
cat integer
/home/sluque/GRASSDATA/Coast_geo/sluque/.tmp/patagonia/18803.1.ppm,
DBMI-DBF driver error:
SQL parser error:
in statement:
update newvect set where cat = 1
Error in db_execute_immediate()
WARNING: Cannot update table
Building topology ...
1 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 2
Number of primitives: 1
Number of points : 0
Number of lines : 0
Number of boundaries: 1
Number of centroids : 0
Number of areas : 0
Number of isles : 0
---<---------------cut here---------------end---------------->---
Seb
