[GRASS-user] v.digit cannot update table
Sat Apr 21 17:14:16 EDT 2007
Seb wrote:
> On Sat, 21 Apr 2007 20:50:19 +0100,
> Glynn Clements <glynn at gclements.plus.com> wrote:
> > Can you try it with:
> > 	export DEBUG=3
> Yes, I tried it with that, but I don't see more messages.  Here's the
> output after trying to draw a square:
> ---<---------------cut here---------------start-------------->---
> v.digit -n map=newvect bg="d.vect coastline"
> New empty map created.
> PNG: GRASS_TRUECOLOR status: TRUE
> PNG: collecting to file:
> /home/sluque/GRASSDATA/Coast_geo/sluque/.tmp/patagonia/18803.0.ppm,
> GRASS_WIDTH=642, GRASS_HEIGHT=289
Are you running it from gis.m?
Try running it from the terminal, after "export DEBUG=3".
