[GRASS-user] Problem with displaing map
Jarosław Jasiewicz
jarekj at amu.edu.pl
Mon Apr 23 04:31:02 EDT 2007
Markus Neteler napisał(a):
>On Mon, Apr 23, 2007 at 09:58:21AM +0200, Jaros??aw Jasiewicz wrote:
>>Hamish napisa??(a):
>>>Jarekj Jasiewicz wrote:
>>>>on cvs updated on 22.04, 20.00
>>>>problem with displaying raster map both in monitor and map display
>>>>nviz also crashes wen I try to display raster
>>>>on d.rast map=mapa error message: Segmentation fault (core dumped)
>Due to the many modifications in CVS, a
> make distclean
>and recompilation is needed. I had the same problem with d.rast
>which disappeared after full recompile.
>Markus
>_______________________________________________
>grassuser mailing list
>grassuser at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grassuser
Thanks Markus
now all is OK
Jarek
