[GRASS-user] Re: Question concerning r.to.vect and out of memory
error
Rainer M. Krug
Rainer at krugs.de
Thu Apr 26 03:18:59 EDT 2007
Hamish wrote:
> Rainer M. Krug wrote:
>>> my system: SuSE 10.2, Dual core processor, 1GP physical memory, 16GB
>>> swap (one swap partition of 1GB and one swap file of 15GB)
>>> I have a huge DEM from which I calculated the slopes and categorised
>>> them in 10% classes. Now I want to use r.to.vect to convert them
>>> into a vector layer of type area. My problem is that I get an out
>>> of memory error, even though there is enough memory available. It
>>> seems that GRASS 6.2.1 only uses the swap partition and not the
>>> swap file (which would be really strange).
>>> by using "free -m" , I got the following memory information (in
>>> megabytes) when r.to.vect quit with an out of memory error:
>>> total used free shared buffers
>>> cached
>>> Mem: 1011 998 12 0 1
>>> 103
>>> -/+ buffers/cache: 894 117
>>> Swap: 17299 1043 16255
>>> Any ideas on how I can avoid this?
>>> By the way: before I started grass, I created the swapfile with
>>> dd ...
>>> mkswap ...
>>> swapon ...
>> One additional information: huge means:
>> Rows: 25960
>> Columns: 23211
>> Total Cells: 602557560
> does the map contain integers or floats?
> (CELL map, FCELL map, or DCELL? [from r.info])
Data Type: CELL
> Even with 16GB ram, Linux can only allocate so much per process.
> see http://kerneltrap.org/node/2450
> Was GRASS built by hand with large file support?
No - I installed it from the rpm for SuSE 10.2
> Was your linux kernel built with CONFIG_HIGHMEM or similar?
I don't think so - I use the standard kernel from SuSE 10.2
(2.6.18.8-0.1 on the one machine - as all updates are done on both
machines, I think that the second one has the same kernel.)
> 32 or 64bit machine? 64bit linux kernel?
32 bit machine
As I think that the problem is not that easy to solve (according to your
- thanks for the link - and Glynns info) without recompiling the
kernel - I will have to go the other route to solve the problem and to
split the raster into smaller ones. As this is a different topic, please
see my other email.
Thanks you to for your help,
Rainer
> Hamish
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
NEW EMAIL ADDRESS AND ADDRESS:
Rainer.Krug at uct.ac.za
RKrug at sun.ac.za WILL BE DISCONTINUED END OF MARCH
Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation
Biology (UCT)
Leslie Hill Institute for Plant Conservation
University of Cape Town
Rondebosch 7701
South Africa
Fax: +27 - (0)86 516 2782
Fax: +27 - (0)21 650 2440 (w)
Cell: +27 - (0)83 9479 042
Skype: RMkrug
email: Rainer.Krug at uct.ac.za
Rainer at krugs.de
