[GRASS-user] Converting slopes from huge DEM into vector (area)
    Rainer M. Krug
    Rainer at krugs.de
    Thu Apr 26 06:35:58 EDT 2007
Hi Hamish
thanks a lot for your information - I'll try it out and come back if I
have further problems
Rainer
Hamish wrote:
> Rainer M. Krug wrote:
>> I have a huge raster, representing the slopes of a huge DEM (Rows:
>>    25960, Columns: 23211, Total Cells:  602557560, Type CELL).
>> I would like to use R.to.vect to convert it to a vector layer of type
>> area. Due to memory requirements, it does not work in one step.
>> I thought of splitting the raster into several smaller rasters (let's
>> say into 100 smaller rasters of the same resolution) for which I could
> you probably only need to split it into 4 parts, not 100.
>> use r.to.vect to create the vector layers and in a final step patch
>> the  vector layers together again.
>> Before going into the details: is this a feasible approach (I can't
>> reduce the resolution as the resolution is needed)
> sure. use v.patch to recombine the parts, but mind the attributes carry
> through.
>> or is there another solution?
> probably several
>> But I am stuck in the first step:
>> how can I split one large raster layer into several smaller?
> actually you don't need to, just change the region with g.region.
> Raster ops only happen in the current region. set the north/south
> bounds to a quarter of the map's height and then r.to.vect will
> only work on that part of it. Vector ops (for the most part) ignore
> the current region settings.
>> and:
>> What is the easiest way to write the script to do the calculations for
>> all 100 raster layers? (I haven't used the scripting in GRASS 6.2.1
>> yet,  but I have done a bit scripting under the bash shell)
> for MAP in `g.mlist type=rast pattern=*` ; do
>    echo "[$MAP]"
>    g.region rast=$MAP
>    r.to.vect $MAP ....
> done
> Hamish
NEW EMAIL ADDRESS AND ADDRESS:
Rainer.Krug at uct.ac.za
RKrug at sun.ac.za WILL BE DISCONTINUED END OF MARCH
Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation
Biology (UCT)
Leslie Hill Institute for Plant Conservation
University of Cape Town
Rondebosch 7701
South Africa
Fax:		+27 - (0)86 516 2782
Fax:		+27 - (0)21 650 2440 (w)
Cell:		+27 - (0)83 9479 042
Skype:		RMkrug
email:	Rainer.Krug at uct.ac.za
       	Rainer at krugs.de
