[GRASS-user] about "@" in mapname in new cvs
Jarosław Jasiewicz jarekj at amu.edu.pl
Thu Apr 26 09:06:02 EDT 2007
Hi
 From sometime (maybe two or three weeks) maps from current mapset in
tcltk interface are inserted as "map_name at mapset" instead of former
"map_name". It causes problems with some gui tools (not in command line):
for example I need to remove some maps from current mapset I chose:
remove maps (g.remove), press ctrl and select for example 20 maps to remove
and I recive command:
g.remove
rast=aspect3_red at smigiel,aspect3 at smigiel,aspect7 at smigiel,diff_mask at smigiel,diff_mask_rec at smigiel,diff_max_region at smigiel
and of course @ is illegal character in map name, no map can be removed
this way
the only way to remove more map in one step is to manually edit every
map name (it is a huge step back)
That problem concerns some other comands, but where there is only one
map it is no so problematic
And for the last - problem concerns only usability tcltk interface not
problems of grass  at all.... I know I can use g.remove rast=map1,map2
etc :)))
It is really nedded  add "@mapset" in current mapset. Or Maybe it is
needed for future grass changes????
Regards
Jarek
