[GRASS-user] about "@" in mapname in new cvs
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Thu Apr 26 09:17:42 EDT 2007
hello,
I had the same problem a few days ago but this bug is already fixed - cvs
update should do it.
http://www.nabble.com/g.remove-with-%40mapset-problem-t3637273.html
Martin
On Thursday, 26. April 2007 15:06:02 Jarosław Jasiewicz wrote:
> Hi
> From sometime (maybe two or three weeks) maps from current mapset in
> tcltk interface are inserted as "map_name at mapset" instead of former
> "map_name". It causes problems with some gui tools (not in command line):
> for example I need to remove some maps from current mapset I chose:
> remove maps (g.remove), press ctrl and select for example 20 maps to remove
> and I recive command:
> g.remove
> rast=aspect3_red at smigiel,aspect3 at smigiel,aspect7 at smigiel,diff_mask at smigiel,
>diff_mask_rec at smigiel,diff_max_region at smigiel
> and of course @ is illegal character in map name, no map can be removed
> this way
> the only way to remove more map in one step is to manually edit every
> map name (it is a huge step back)
> That problem concerns some other comands, but where there is only one
> map it is no so problematic
> And for the last - problem concerns only usability tcltk interface not
> problems of grass at all.... I know I can use g.remove rast=map1,map2
> etc :)))
> It is really nedded add "@mapset" in current mapset. Or Maybe it is
> needed for future grass changes????
> Regards
> Jarek
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
