[GRASS-user] Question about databases and vector files...
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Apr 26 10:24:18 EDT 2007
On 4/26/07, Hamish <hamish_nospam at yahoo.com> wrote:
> Jonathan Greenberg wrote:
> > Will all v.XXX commands work on vector files regardless of which
> > database is hosting the files? E.g. if I have a point file that is in
> > a postgis DB, can I use commands such as v.buffer (and also have the
> > results put back into a postgis format)?
> yes, they should.
> Hamish
Hamish: are your refering to the attributes or the geometry? I was not
aware that GRASS can operate directly on postgis geometry.
Dylan
