Jonathan Greenberg wrote: > > Will all v.XXX commands work on vector files regardless of which > database is hosting the files? E.g. if I have a point file that is in > a postgis DB, can I use commands such as v.buffer (and also have the > results put back into a postgis format)? yes, they should. Hamish
