[GRASS-user] about "@" in mapname in new cvs and reclass (fixed)
Jarekj Jasiewicz jarekj at amu.edu.pl
Thu Apr 26 13:09:28 EDT 2007
Glynn Clements napisał(a):
> Jaros-Bław Jasiewicz wrote:-A
>> It is really nedded  add "@mapset" in current mapset.
> In general, yes. An unqualified map name refers to the first map with
> that name found in the mapset search path, which isn't necessarily the
> map with that name in the current mapset (the default search path has
> the current mapset first, but that can be changed).
> Even if the map is currently the first one found with that name in the
> search path, that can change if maps or added or removed or if the
> search path is changed. Re-running the command would then have
> unexpected results if an unqualified name was used.
> As Martin said, the specific bug in g.remove (actually, in the
> G_remove() function which it uses) has since been fixed.
Thanks, now is OK, I stopped cvs updating due to problems with
r.reclass, now all bugs are fixed
thanks for information and your help
Jarek
