[GRASS-user] r.reclass and g.remove: another issue
Jarekj Jasiewicz
jarekj at amu.edu.pl
Thu Apr 26 13:26:43 EDT 2007
IProblem concerns cvs update from april, 26, 19:13 EET
The test of bugfix from r.reclass and g.remove reveals another small
problem: the map wchich is base map for reclassed map cannot be removed
even if reclassed map is removed first:
on spearfish:
I created new map "abc" (copy of elevation.dem form PERMANENT)
and created a reclassed "abc" map named "cdf"
I tried:
g.remove rast=cdf at nowe
GRASS_INFO_MESSAGE(28577,1): Removing raster <cdf at nowe>
(map cdf not exist)
next:
I tried to remove map abc:
g.remove rast=abc at nowe
GRASS_INFO_WARNING(28608,1): [abc at nowe@nowe] is a base map. Remove
reclassed map first: cdf at nowe
I tried also:
g.list type=rast
and I recived:
raster files available in mapset nowe:
abc
raster files available in mapset PERMANENT:
aspect bugsites density ..............
The problem is beacause:
in:
~/spearfish60/nowe/cell_misc/abc
exist file reclased_to with "cdf at nowe"
if reclased_to will be removed manually base map can be removed without
problem. Unfortunatly I don't how to fix it
Jarek
