[GRASS-user] Question about databases and vector files...
    Glynn Clements
    glynn at gclements.plus.com
    Thu Apr 26 18:37:31 EDT 2007
Jonathan Greenberg wrote:
> As I said -- lots of newbie questions here (I'm a raster man, just now
> beginning to learn the intricacies of vector files beyond "hey, it's a bunch
> of points") -- is there any inherent size limitation for vector files (the
> geometry portion) in grass?
On a 32-bit system, you will probably be limited to 2GiB for each file
(the coordinate data is usually the largest file).
AFAIK, the --enable-largefile option doesn't currently apply to vector
files.
