[GRASS-user] xganim & underlying data?
Markus Neteler neteler at itc.it
Tue Aug 7 17:09:43 EDT 2007
Mark,
Maris Nartiss did some NVIZ animations, get from:
http://mpa.itc.it/markus/grass61/demos/rlake/
Maybe that's what you are looking for,
Marks
M S wrote:
> Thanks for the reply.
> Any suggestions on how to convert/integrate an r.lake output (the blue
> color
> map is very nice) with a DEM "elevation" colormap?
> Mark
> On 8/7/07, Glynn Clements <glynn at gclements.plus.com> wrote:
>> M S wrote:
>> > In xganim, is it possible to use an underlying raster such as a DEM
>> with
>> an
>> > elevation colormap or vector contours?
>> Each frame has to be a GRASS raster map. If you want to use anything
>> else, you have to convert it.
View this message in context: http://www.nabble.com/xganim---underlying-data--tf4231698.html#a12042088
Sent from the Grass - Users mailing list archive at Nabble.com.
