[GRASS-user] xganim & underlying data?
    M S
    mseibel at gmail.com
    Tue Aug  7 18:15:17 EDT 2007
Thanks!  that is similar to what I am currently trying to do, but also fits
another application of GIS that I need to eventually get to.
that link is truly an incredible application of GIS.  that is a very
powerful illustration.  It seems that I need to look into NVIZ.  That may
also explain the use of negative depth values, which i didnt understand in
the raster data model.
On 8/7/07, Markus Neteler <neteler at itc.it> wrote:
> Mark,
> Maris Nartiss did some NVIZ animations, get from:
> http://mpa.itc.it/markus/grass61/demos/rlake/
> Maybe that's what you are looking for,
> Marks
> M S wrote:
> > Thanks for the reply.
> > Any suggestions on how to convert/integrate an r.lake output (the blue
> > color
> > map is very nice) with a DEM "elevation" colormap?
> > Mark
> > On 8/7/07, Glynn Clements <glynn at gclements.plus.com> wrote:
> >> M S wrote:
> >> > In xganim, is it possible to use an underlying raster such as a DEM
> >> with
> >> an
> >> > elevation colormap or vector contours?
> >> Each frame has to be a GRASS raster map. If you want to use anything
> >> else, you have to convert it.
> http://www.nabble.com/xganim---underlying-data--tf4231698.html#a12042088
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070807/793b1588/attachment.html
