[GRASS-user] M.proj in Grass-GIS 6.3 CVS on Mac OSX
    William Kyngesburye
    woklist at kyngchaos.com
    Tue Aug  7 18:42:52 EDT 2007
Normally, extra tools are expected to be in the user's shell PATH.
Since the frameworks have a separate bin path for each one, they
won't be found in the common /usr/local/bin, and many Mac users may
not think to add them.
I took care of this in the Mac startup for GDAL, since I knew that
GDAL was used in a GRASS module, but I wasn't aware that m.proj used
PROJ tools.  I can fix that for future builds.  For now, type this in
GRASS:
export PATH="/Library/Frameworks/PROJ.framework/Programs:$PATH"
On Aug 7, 2007, at 4:57 PM, Richard Chirgwin wrote:
> Hi,
> I need to convert a map from Lambert Conformal Conical projection
> to a lat-long projection.
> I'm using the William Kyngesbury build of Grass 6.3, and have
> installed the frameworks. However, when I try to run M.proj, I get
> the error:
> > csc2 program not found, install PROJ.4 first
> I had previously been using Grass 6.2, and had installed the
> frameworks on my first install. Grass 6.3 runs okay, so I had
> thought it was finding the frameworks okay, but apparently not PROJ.
> 4. What should I do to make sure 6.3 can find the frameworks?
> (PS - thanks to the list for previous vector-raster assistance, I
> haven't worked through everything yet but will let the list know
> what worked when I get to it!).
> Richard Chirgwin
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
