[GRASS-user] v.edit bus error
    Hazael Maldonado Torres
    hmaldonado at itxolutions.com
    Wed Aug  8 13:35:26 EDT 2007
Hi there,
I am trying to edit a vector map using the command 'v.edit', however, it keeps
failing with a 'bus error' message.
The version I am running is 6.3.cvs (070623) which is available at
http://wwwamb.bologna.enea.it/forgrass/download.htm
Does any one is getting this error? Is there a tool to fill out a bug report?
I will describe the task I want to do via 'v.edit' just in case someone knows a
way around. I have a vector map with some areas having 2 categories in the same
layer (this was the result of overlapping areas in the Shapefile). I have to
leave each of these areas with only one category so I was using the following
command:
v.edit n tool=caldel cat=3117 id=49792
Thanks
Hazael
