[GRASS-user] v.edit bus error
William Kyngesburye
woklist at kyngchaos.com
Wed Aug 8 13:58:49 EDT 2007
That's probably the same bug I just found in another module, and is
present in v.edit also. Bug already filed, and it's in the process
of being fixed.
On Aug 8, 2007, at 12:35 PM, Hazael Maldonado Torres wrote:
> Hi there,
> I am trying to edit a vector map using the command 'v.edit',
> however, it keeps
> failing with a 'bus error' message.
> The version I am running is 6.3.cvs (070623) which is available at
> http://wwwamb.bologna.enea.it/forgrass/download.htm
> Does any one is getting this error? Is there a tool to fill out a
> bug report?
> I will describe the task I want to do via 'v.edit' just in case
> someone knows a
> way around. I have a vector map with some areas having 2 categories
> in the same
> layer (this was the result of overlapping areas in the Shapefile).
> I have to
> leave each of these areas with only one category so I was using the
> following
> command:
> v.edit n tool=caldel cat=3117 id=49792
> Thanks
> Hazael
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
