[GRASS-user] Associating attributes from Postgres file with a key other than cat
Turner, James James.Turner at kronos.com
Wed Aug 8 16:28:33 EDT 2007
Ok, next dumb question that the documentation didn't seem to help with
I have the Census ZCTA data loaded up "locally" (not in a database), and
some proprietary zip-code based data in a Postgres DB table.  The
Postgres data is keyed off the zip code, and obviously knows nothing
about the cat #s of the imported e00 file with the ZCTA data.  Is there
any non-trivial way to make the values in the Postgres table available
to GRASS so that I can use it to do coloring of areas, etc.
And yes, I know that ZCTA <> Zip Code, but it's close enough for this
application.
James M. Turner
Senior Software Engineer - Kronos Labs
Kronos, Inc.
2 Omni Way, Chelmsford, MA 01824
(w) 978-947-4108, (c) 603-552-2020, (f) 978-256-2477
jamesturner at kronos.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070808/18860270/attachment.html
