[GRASS-user] Batch Processing in GRASS 6.2 w/ Cygwin
Glynn Clements
glynn at gclements.plus.com
Thu Aug 9 07:16:24 EDT 2007
Steve Hanser wrote:
> I need more help. I implemented the suggestions from Glynn and edited the
> file in emacs. I no longer receive any error messages but the script does
> not run any GRASS processes. Here is the current version of the script.
> Obviously I am new to this so I appreciate any help I can get. I have
> about 100 processes to complete and a batch script is the only way I think
> I'll get it done. Thank you.
If you just need to script GRASS commands, it's easier to just run a
script from within a GRASS session than to script the creation of the
session.
> GISBASE="/cygdrive/c/cygwin/usr/local/grass-6.2.2"
This probably won't harm anything, but it's better to use Cygwin
pathnames for files and directories within the Cygwin hierarchy, i.e.:
GISBASE="/usr/local/grass-6.2.2"
> # Generate Grass settings:
> echo "GISDBASE: $GISDBASE
> LOCATION_NAME: newset
> MAPSET: PERMANENT" > $HOME/.grassrc6
Multi-line strings aren't robust; it's better to use either a
here-document:
cat > "$HOME/.grassrc6" <<-EOF
GISDBASE: $GISDBASE
MAPSET: PERMANENT
EOF
or a subshell:
echo "GISDBASE: $GISDBASE"
echo "LOCATION_NAME: newset"
echo "MAPSET: PERMANENT"
) > "$HOME/.grassrc6"
or multiple commands appending to the file:
echo "GISDBASE: $GISDBASE" > "$HOME/.grassrc6"
echo "LOCATION_NAME: newset" >> "$HOME/.grassrc6"
echo "MAPSET: PERMANENT" >> "$HOME/.grassrc6"
> export LD_LIBRARY_PATH=/cygdrive/c/cygwin/lib:$GISBASE/lib:$LD_LIBRARY_PATH
LD_LIBRARY_PATH is specific to Linux and SunOS/Solaris. Windows
(including Cygwin) uses PATH to located DLLs:
export PATH="$GISBASE/lib:$PATH"
[Cygwin's DLLs are in its "bin" directory, which will already be in $PATH.]
It's probably the fact that $GISBASE/lib is missing from $PATH that's
preventing your script from working. If a Cygwin binary cannot find
its DLLs, it simply terminates without error.
