[GRASS-user] Batch Processing in GRASS 6.2 w/ Cygwin
Hamish
hamish_nospam at yahoo.com
Mon Aug 13 23:20:51 EDT 2007
Glynn Clements wrote:
> Your script appears to be using CRLF line termination; you need to use
> LF (the CR will be treated literally, causing all kinds of errors).
> This rules out using Notepad to edit scripts. Cygwin has packages for
> vim, emacs and xemacs.
FWIW,
TextPad is a nice editor for Windows which lets you choose newline
format when you Save As..
nedit is a nice editor for UNIX that will run in Cygwin. (there's a pkg)
It also lets you choose newline format.
Hamish
