[GRASS-user] v.edit bus error
William Kyngesburye
woklist at kyngchaos.com
Thu Aug 9 10:16:39 EDT 2007
On Aug 9, 2007, at 7:33 AM, Hazael Maldonado Torres wrote:
> Hi there,
> Before answering the questions from William, I would like to
> mention that GRASS
> is being run on an Intel Mac and that as far as I can tell (using
> the activity
> monitor) it is the Intel binaries of GRASS that are being used (no
> Rosseta).
I checked Lorenzo's binaries, and they're PPC only, at least the 6.3
CVS are. PPC processes appear as normal processes on Intel, the
Rosetta translation is transparent. I don't see anything in Activity
Monitor that will tell you the architecture of a process. It's
probably because, by the time it's running as a process, Rosetta has
translated it into Intel code.
>> Hazael, can you check Console.app for a crashlog for v.edit? It
>> would
>> be in ~/Library/Logs/CrashReporter in the log list.
> There is nothing in the logs regarding the v.edit error message. I
> also tried at
Odd.
I guess if there is no verification that your v.edit problem failed
because of the null messages, the thing to do is see if a new build
with the null messages fixed works.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
