[GRASS-user] v.edit bus error
    Glynn Clements
    glynn at gclements.plus.com
    Thu Aug  9 10:56:26 EDT 2007
Hazael Maldonado Torres wrote:
> > If it's the null message causing the v.edit bus error, then it is, since
> > I found a null message in v.edit, among others.
> I have written an small program to test the G_message("") vs G_message(NULL) and
> I can confirm that on Mac OS X 10.4.10 G_message(NULL) triggers a bus error.
Odd. In that case, it probably is the G_message(NULL).
