[GRASS-user] Problem with GRASS 6.3 startup
Vincent BAIN
bain at toraval.fr
Tue Aug 14 05:29:30 EDT 2007
Perhaps I did not catch your actual problem, but did you have a look
here ?
http://grass.itc.it/pipermail/grassuser/2007-August/040757.html
I had the same kind of pb when I compiled gdal from sources.
Le lundi 13 août 2007 à 20:11 -0400, Thomas.Adams at noaa.gov a écrit :
> List,
> Actually this is not a new problem per se; it seems every time I build a new version of GRASS from source the Tcl/Tk GUI
> fails to come up when I hit 'Enter' after selecting the Location, Mapset, etc. What happens is that the GUI trys to come-up,
> flashes, and I get an error in the Term window that references a .tcl file at the last line of the start-up script.
> My inelegant way of handling this in the past was to simply copy shared libraries for gdal, Tcl/Tk, and proj4 into the GRASS
> lib directory. I would like to do this in a better way; what should I do? Unfortunately, I have to build *everything* in a non-
> standard location due to system constraints.
> What makes my current situation more difficult is that I am in another office (Salt Lake City, Utah), trying to help them get
> going with GRASS and my 'fix' is not working. What we ended up doing was to secure copy my Tcl/Tk shared libs from my
> machine in Ohio to the one we're installing on, and it's not working.
> Supposedly, the systems I'm working on have Tcl/Tk installed, but we could not find the shared libs. Should we build Tcl/Tk
> locally to ensure compatability? Is this the likely problem?
> Thanks,
> Tom
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
