[GRASS-user] Importing .e00 file
M S mseibel at gmail.com
Wed Aug 15 06:49:05 EDT 2007
Looks like it is a raster/GRID, and not vector?
On 8/15/07, Rainer M. Krug <Rainer at krugs.de> wrote:
> Hi
> System:
> SuSE Linux 10.2
> grass 6.2
> e00compr-1.0.0
> avce00-2.0.0
> I want to import an .e00 file, but I get the following error message:
> > v.in.e00 -v file=aveanrfl.e00 type=area vect=test
> An error may appear next which will be ignored...
> E00 Compressed ASCII found. Will uncompress first...
> ...converted to Arc Coverage in current directory
> Importing areas...
> ERROR: Cannot open data source: aveanrfl
> An error occurred. Stop.
> I get the same area message if I omit the extension .e00 from
> file=aveanrfl.e00
> I attach the first lines of the .e00 file:
> EXP  0 /DUMP/GISDATA/RSAMAPGD.E00
> GRD  2
>        1075       910 1-0.21474836470000E+10
>   0.16667000000000E-01 0.16667000000000E-01
>   0.16091670000000E+02-0.34875030000000E+02
>   0.34008695000000E+02-0.19708060000000E+02
>             403           403           403           403           404
>             405           407           407           408           421
>             420           429           433           439           427
>             433           436           426           428           429
>             432           433           434           447           448
>             448           447           448           464           460
>             459           464           480           472           477
>             482           469           487           494           485
>             490           488           487           496           484
>             479           484           485           472           477
> Any idea how I can import this file?
> Thanks,
> Rainer
> NEW EMAIL ADDRESS AND ADDRESS:
> Rainer.Krug at uct.ac.za
> RKrug at sun.ac.za WILL BE DISCONTINUED END OF MARCH
> Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation
> Biology (UCT)
> Plant Conservation Unit
> Department of Botany
> University of Cape Town
> Rondebosch 7701
> South Africa
> Tel:            +27 - (0)21 650 5776 (w)
> Fax:            +27 - (0)86 516 2782
> Fax:            +27 - (0)21 650 2440 (w)
> Cell:           +27 - (0)83 9479 042
> Skype:          RMkrug
> email:  Rainer.Krug at uct.ac.za
>         Rainer at krugs.de
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070815/6958e803/attachment.html
